Nouveau carbus AMAL
Publié : 05 mai 2021, 22:51
Re: Nouveau carbus AMAL
Publié : 05 mai 2021, 23:24
par Joël 29
Vu sur le site Burlen :
AMALminium Premier Carbs
The AMAL Carburetter Company, (Burlen Fuel Systems Ltd), the world’s sole manufacturers of all genuine new AMAL Carburetters and spares, are pleased to announce the launch of a new Lightweight Premier Carburetter in Aluminium.
As a further step in the improvement and development of their carburetters AMAL are now offering special light weight versions of their 600 Series Premier carburetters with the body and float bowl cast in aluminium. The carburetters include all the parts developed by AMAL for the Premier carburetter – hard anodised aluminium throttle valve, ethanol resistant Stay-up float, removable pilot Jet and aluminium needle valve and have been comprehensively tested on the road and have already clocked up several trials successes. Genuine AMAL jets guarantee accuracy and consistency of performance.
The carburetters are available with bore diameters of 20mm, 22mm, 24mm, 26mm and 27mm and both right-hand and left-hand versions are available. The aluminium carburetter offers a weight reduction of around ¾ lb over the traditional zinc alloy type.
The carburetters can be supplied to standard specifications or customised to suit individual requirements and are supplied with the usual two year AMAL warranty, backed by our technical advice service available to all AMAL customers.
Available now directly from the AMAL Carburetter Company via telephone on 01722 412500 or by email at
info@amalcarb.co.uk
Publié : 06 mai 2021, 07:43
par Michel J
On espère que l'alu permette à Amal un grand bon technologique dans l'usinage .....des petits trous...
Publié : 06 mai 2021, 08:07
par Tricati
Il y a déjà quelques années que ces carbus en aluminium existent, au départ seuls les 27 mm pour Trident et autres existaient, j'en ai monté en 2018, la finition est meilleure et ils sont plus légers, ils sont quand même à vérifier à réception, à l'époque les gicleurs de ralenti non percés, niveau de cuve non identiques sur les 3, etc.... !
De plus c'est "out "of stock" pour l'instant chez Burlen quelles que soit les références......
J'ai attendu 3 mois des 930 cet automne.....
Publié : 06 mai 2021, 08:19
par Hans Otto
L'aspect exterieur ressemble aux Wassel,sans doute la meme matiere
Publié : 06 mai 2021, 10:12
par Shadock44
Euh... Et si l'aluminium c'est tellement mieux, que ça s'use moins et c'est plus léger, pourquoi les ont-ils fabriqués si longtemps en Zinc* ?
(*ou un alliage contenant du Zinc ?)
Les mecs découvrent l'aluminium et c'est une révélation...
Publié : 06 mai 2021, 12:59
par Michel J
Shaddock tu devrais savoir que l'industrie britannique à besoin d'une période de validation dans les progrès technologiques "revolutionnaire".. ou pourquoi faire évoluer un produit zinc qui fait le job ....☺☺....peut etre un nouveau directeur chez Amal Burlen
