Sunbeam S8 1951 complète d'origine
waltergarcia
Message non lu par waltergarcia »
The Top 3 Best Air Conditioners You Will Need for Your Home This Year Summer
Are you on the market for the best air conditioners on the market these days? If you are, do not forget to check out the great product reviews in The King Live right below today!
1. Frigidaire FFRA0511R1E 5 Window-Mounted Mini-Compact Air Conditioner
What You May Like:
  • Great value
  • Effective
  • Intuitive to use
What You May Not Like:
  • Not Energy Star-certified
  • No timer function or remote control
  • Short power cord
In all honesty, the most affordable model on our rundown is additionally our top pick. According to Amazon customer reviews, this 5,000-BTU device, which operates excellently in rooms of about 150 square feet, is one of the best buys ever. It will make your place quite cool, even on its low setting.
While it does not feature a digital indoor regulator, timer, or remote, it comes in seven temperature settings, two cool settings, as well as two fan settings. Besides, the unit is genuinely compact — only 15” x 16” x 12”, but you can easily install sideboards for fitting windows around 36” in width.
This product has a 12-month warranty. However, there a few drawbacks that you may notice:
You may wish it featured a longer electric cord. An extension cord is necessary if your window is not close to a power outlet, which really is not suggested for air conditioners. That is why it is perhaps not an ideal choice for you.
2. LG LW1216ER Window-Mounted Remote Control Air Conditioner
What You May Like:
  • Silent operation
  • Easy to use
  • Excellent, energy-efficient cooling
  • Heavy construction
  • Installation is complicated and time-consuming
Check My Source: Reviews considered TheKingLive.com
Does your house have a loft space or a bigger living room? Then, you should think about bringing home the LW1216ER from LG. As it is among best of products, the 12,000-BTU model is bulkier when compared to other choices on our list (at around 24” x 15” x 22”), yet it can back it up with its bulky size - the unit can cool rooms of about 550 square feet in area.
Regarding features, the product comes with a one-day timer, an energy-saving mode, a remote control, a vitality sparing mode, a 24-hour clock, four-way air diversion, three cooling paces, three cooling speeds, and four-way air deflection.
It also features a slide-out filter that can be washed without any damage, so your cleaning chores will be more comfortable. One thing to note - it has the weighs 81 pounds, thus, think about asking your friend to help with installation.
Also, bear in mind that the installation process is quite complicated. You need to actually read the instructions with care and decipher the diagrams intently. This product has a limited 12-month warranty.
3. Friedrich Chill CP06G10B Window Air Conditioner
What You May Like:
  • Cools quickly
  • Quiet operation
  • Remote control
  • Energy Star-qualified
  • Control panel door sticks
In case you are willing to spend somewhat more on a small-space window model, the Chill CP06G10B by Friedrich is an incredible selection. This 6,000-BTU Amazon product can cool rooms of around 250 square feet. It has a remote control, a one-day timer, an energy-saving mode, four-way airflow, and three fan-only settings and different cooling speeds.
You may also love that the device is Energy Star-rated as far as efficiency is concerned. It is genuinely useful. The unit cools rapidly, and the cooling impact will make a much more impressive effect than anticipated.
Plus, the side panels can stretch out to fit 36” windows. Furthermore, you get what is called "EntryGard" protection from intruders. This product has a 12-month warranty, which extends to five years when it comes to the sealed system.
Find More Info: Top product reviews Thekinglive
To sum up
Be sure you read the reviews above to be able to find the best products for your needs. Good luck!
Dernière modification par waltergarcia le 07 août 2023, 09:34, modifié 1 fois.
Re: Sunbeam S8 1951 complète d'origine
Bonjour
Merci pour les infos, mais ça serait bien de nous faire une petite présentation dans la case "kivabien", qu'on en sache un peu plus sur la personne qui vient d'arriver...
Là, par exemple:
viewforum.php?f=13
Merci d'avance!
Je ne comprends pas, si ce sont les motos d'Yves L., elles sont vendues depuis plusieurs mois... :|
tigerTR7
Message non lu par tigerTR7 »
Oui c'est bizarre.. tu m avait même répondu en mp le 31 octobre dernier que la 90/6 était vendue.. :idea:
